Originariamente inviato da ToniPons
Questo è quello che vedo nel file APM_config.h
// -*- tab-width: 4; Mode: C++; c-basic-offset: 4; indent-tabs-mode: nil -*-
// User specific config file. Any items listed in config.h can be overridden here.
// If you used to define your CONFIG_APM_HARDWARE setting here, it is no longer
// valid! You should switch to using a HAL_BOARD flag in your local config.mk.
// If you have CRIUS V1 - Uncomment next line to disable logging
#define LOGGING_ENABLED DISABLED // disable logging for boards without dataflash chip
// If Arduino IDE hang while uploading firmware to your board, try to change string below, just enter some random characters
#define BOOTLOADER_BUGFIX "234fs34567hf"
// Currently not supported
#define CONFIG_SONAR DISABLED
//#define HIL_MODE HIL_MODE_SENSORS // build for hardware-in-the-loop simulation
//#define HIL_MODE HIL_MODE_ATTITUDE // build for hardware-in-the-loop simulation
// QuadCopter selected by default
//#define FRAME_CONFIG HEXA_FRAME
* options:
* QUAD_FRAME
* TRI_FRAME
* HEXA_FRAME
* Y6_FRAME
* OCTA_FRAME
* OCTA_QUAD_FRAME
* HELI_FRAME
// User Hooks : For User Developed code that you wish to run
// Put your variable definitions into the UserVariables.h file (or another file name and then change the #define below).
//#define USERHOOK_VARIABLES "UserVariables.h"
// Put your custom code into the UserCode.pde with function names matching those listed below and ensure the appropriate #define below is uncommented below
//#define USERHOOK_INIT userhook_init(); // for code to be run once at startup
//#define USERHOOK_FASTLOOP userhook_FastLoop(); // for code to be run at 100hz
//#define USERHOOK_50HZLOOP userhook_50Hz(); // for code to be run at 50hz
//#define USERHOOK_MEDIUMLOOP userhook_MediumLoop(); // for code to be run at 10hz
//#define USERHOOK_SLOWLOOP userhook_SlowLoop(); // for code to be run at 3.3hz
//#define USERHOOK_SUPERSLOWLOOP userhook_SuperSlowLoop(); // for code to be run at 1hz
